Changed network drive letter and can't access render output tools
Question asked by Matthew Lomelin on May 11, 2017
Latest reply on May 12, 2017 by Matthew Lomelin
There should be another way to access the render output options. Anyway, we needed to change our drive letter, and now I get an error and it won't let me access the render output options at all. I reset everything from the tools options and it still doesn't work. Help please.
An error has occurred.
Error occurred at 14:28:36 on Thursday, 11 May 2017.  Build version is 25.2.0.52.
System.IO.DirectoryNotFoundException = "Could not find a part of the path 'Z:\Visualize\Renders'."
Stack Trace:
   at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
   at System.IO.Directory.InternalCreateDirectory(String fullPath, String path, Object dirSecurityObj, Boolean checkHost)
   at System.IO.Directory.InternalCreateDirectoryHelper(String path, Boolean checkHost)
   at Bunkspeed.Rendering.ApplicationLayer.Controllers.SnapshotManager.GetNextAvailableFilename(String outputFolder)
   at Bunkspeed.Rendering.ApplicationLayer.Controllers.SnapshotManager.RefreshSnapshotFileName(String outputFolder)
   at Bunkspeed.Rendering.ApplicationLayer.ViewModels.RenderingOptionsViewModel..ctor(DocumentViewModel documentViewModel, IUserSettings userSettings, ISystemInfo systemInfo, IMainWindowController mainWindowController, IComposerProductSettings productSettings, IAnimationPlaybackManager animationPlaybackManager, RenderProfilesDataProvider renderProfilesDataProvider, INotifications notifications, ICommandLine commandLine)
System.Reflection.TargetInvocationException = "Exception has been thrown by the target of an invocation."
Stack Trace:
   at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
   at System.Reflection.RuntimeConstructorInfo.Invoke(BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
   at System.RuntimeType.CreateInstanceImpl(BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes, StackCrawlMark& stackMark)
   at System.Activator.CreateInstance(Type type, BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes)
   at System.Activator.CreateInstance(Type type, Object[] args)
   at Bunkspeed.ObjectPanarchy.Panarchy.Builder.BuildTransaction.BuildDown(Type type)
System.ArgumentException = "Failed to build type Bunkspeed.Rendering.ApplicationLayer.ViewModels.RenderingOptionsViewModel"
Stack Trace:
   at Bunkspeed.ObjectPanarchy.Panarchy.Builder.BuildTransaction.Build(Type type)
Bunkspeed.ObjectPanarchy.Panarchy.Builder.BuildFailedException = "Build failed on type RenderingOptionsViewModel
Stack Trace:
   at Bunkspeed.ObjectPanarchy.Panarchy.Builder.BuildTransaction.Build(Type type, Dictionary`2 arguments)
   at Bunkspeed.ObjectPanarchy.Panarchy.Container.ContextContainer.DoBuild(Type type, Dictionary`2 arguments)
   at Bunkspeed.ObjectPanarchy.Panarchy.Container.ContextContainer.Get[T]()
Bunkspeed.ObjectPanarchy.Panarchy.Builder.BuildFailedException = "Failed to build in context IMainDocumentContext
Stack Trace:
   at Bunkspeed.Rendering.ApplicationLayer.Controllers.DocumentManager.GetRenderingUserOptionsFromDialog(Boolean showOptionsDialog)
   at Bunkspeed.Rendering.ApplicationLayer.Controllers.DocumentManager.Render(Boolean showOptionsDialog, Boolean showInExternalWindow, IProjectCurrents projectCurrents)
   at Bunkspeed.Rendering.ApplicationLayer.MainViewportController.RenderScene(Object sender, MouseButtonEventArgs e)
   at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
   at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
   at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
   at System.Windows.UIElement.ReRaiseEventAs(DependencyObject sender, RoutedEventArgs args, RoutedEvent newEvent)
   at System.Windows.UIElement.OnPreviewMouseDownThunk(Object sender, MouseButtonEventArgs e)
   at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
   at System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args)
   at System.Windows.Input.InputManager.ProcessStagingArea()
   at System.Windows.Input.InputManager.ProcessInput(InputEventArgs input)
   at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
   at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
   at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
   at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
   at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
Direct3D Device Feature Level: Level_11_0
Microsoft Windows 10 Pro Service Pack -1 - Pass
8 x Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz - Pass
16346 MB RAM available - Pass
4095 MB NVIDIA Quadro K2200 - Pass
09/16/2016 00:00:00 GraphicsCard drivers - Attention
1 CUDA devices
151885 MB disk space free - Pass
1896 MB ram used by application
NeurayDeviceMode is Hybrid
