circularpattern3 works in vba but not in vb6
Question asked by James Townzen on May 11, 2017
Latest reply on May 12, 2017 by Ivana Kolin
I have an SolidWorks assembly with 3 components:
     a ball bearing
     an inner ring
     an outer ring
What I want is to add a circular pattern within the bearing assembly:
I recorded a vba macro that works when ran within the open assembly, through the vba macro editor
but does not work within vb6.
I have other code that opens SolidWorks, open the parts (components), opens the bearing assembly
and changes some dimensions. These work but I can't get the circular pattern to build from vb6.
There are no error messages but nothing happens when I run the code below.
This is a list of declarations I tried.
Dim swAssm As SldWorks.AssemblyDoc
Dim swConfg As SldWorks.Configuration
Dim swAnnotations As SldWorks.Annotation
Dim swConfigMgr As SldWorks.ConfigurationManager
Dim swConf As SldWorks.Configuration
Dim swDim As SldWorks.Dimension
Dim swFeat As SldWorks.Feature
Dim swFillPat As FillPatternFeatureData
Dim boolstatus As Boolean
Dim longstatus As Long
Dim longwarnings As Long
Code Body:
Private Sub Command6_Click()
Set swAssm = swApp.ActivateDoc("BearingAssembly")
     boolstatus = swPart.Extension.SelectByID2("Ball-1@BearingAssembly", "COMPONENT", 0, 0, 0, True, 0, Nothing, 0)
     boolstatus = swPart.Extension.SelectByID2("Axis1", "AXIS", 0, 0, 0, True, 0, Nothing, 0)
swPart.ClearSelection2 True
     boolstatus = swPart.Extension.SelectByID2("Ball-1@BearingAssembly", "COMPONENT", 0, 0, 0, False, 1, Nothing, 0)
     boolstatus = swPart.Extension.SelectByID2("Axis1", "AXIS", 0, 0, 0, True, 2, Nothing, 0)
Set swFeat = swPart.FeatureManager.FeatureCircularPattern3(21, 0.299199300341886, False, "NULL", True, False)
     swPart.ForceRebuild
Code:\
Thanks for any suggestions
Jim Townzen
PS: I have Visual Basic 6 Pro Edition, SolidWorks 2016, Windows 7 64
The reason I'm using VB6 is to make a simple stand-a-lone program.
