I have attached the (imported) part and I would like someone to explain how to cut the holes on the sketch #1. I use SW2015.
But generally....
In order to cut a surface you need to do one (or more) of the following:
1) Extrude another surface and use it to trim the 1st surface
2) Sketch on the first surface (or create a sketch and then project onto surface) and use the sketch(projection) to trim the surface
3) Thicken the surface, then you can use Feature stuff (like extrude cut, hole wizard, etc...)
But generally....
