Sheetmetal - how to insert a note with custom cut list item properties in drawing? InsertCutListPropertyNote macro.
Question asked by Wojciech Pogorzelski on May 11, 2017
Latest reply on Jul 15, 2017 by Wojciech Pogorzelski
Hi All,
I’m trying to find a way to get a custom Cut List Property Note in a drawing from a flat pattern sheet metal part.
A standard note consist a lot of useless information for me.
I spend a few days searching for the solution over the internet and ended with nothing.
Is there a way to modify a standard note, so it displays only the lines I need and save it as a standard?
I don’t need to add anything extra to it, just less information that the standard note gives.
Or maybe there is a way to modify this macro I have found:
2016 SOLIDWORKS API Help - Insert Cut List Item Property Note Example (VBA)
It puts the standard note in a specified location on a sheet, such is great, except I would like to shorten to a few specified lines:
Sheet Metal Properties:
- Thickness:
- Bend Radius:
- Number of Bends:
- Number of Cuts:
- Outer cutting length:
- Inner cutting length:
- Material:
- Weight:
Thank you for any help in advance
