I'm not sure if this can be done in sheet metal. I need to take a strip of metal, thin about .060 thick, 12 in long, 2 in wide, two holes in each end so you can bend it into a circle and bolt it together. WHAT WOULD BE THE BEST WAY TO DO THIS?
I would definitely use this for a sketch controller, in other words create the spline and split into sections, then make it a construction line then add circles that are related with three points, but because of the helix nature you should have at least 4 circle sketches that are trimmed to flow within the spline..
Attached is a 2017 part, I can use Sheet Metal to do the base extrude but it doesn't want to flatten - maybe Frank Ruepp could chime in... I know you can't use any spline sketches, however I used arcs to develop the final sketch...
Hi John,
I had a look at your part and there are a couple of things. Basically you can create two different types of base flanges:
I hope this has shed some light into the obscurity of sheet metal.
Kind regards
Frank
SOLIDWORKS Product Definition Team
I would draw your curve, you'll probably have to use a spline on two planes your thickness apart since you want it to over lap, and then use lofted-bend. You can select the the thickness. After can then extrude a hole through, if you want you can do it in the rolled state or flattened state.
