Hello, 3 corners 45 degrees, 1 corner 90 degrees. Why can not I turn it off with a corner command? Please help me.
You can not do it with the "closed corner" you want, but you can do it manually
Nilhan,,, it does work for me. It would be interesting to see what is different in your file which is causing it not to work. Can you attach your file?
