Edmond Husseini
Spring force
Discussion created by Edmond Husseini on Dec 16, 2008
Latest reply on Mar 25, 2009 by Ian Hogg
I am having trouble plotting the magnitude of the resultant spring force between two components.
I have two components vertically aligned in an assembly that are separate in free space, with one component being fixed to the assy origin.. I have added gravity, material specs and a spring/damper combo between the two components in the motion assembly. I run the simulation and the lower components oscillates for a while and then comes to rest as it should.
I am trying to plot the tensile/compression force exerted by the applied spring/damper combo.. How do I go about doing this?
Much appreciated in advance.
