Hi all,
I'm trying to update a number of drawings to a new drawing template while keeping the views and dimensional callouts intact. After doing some research, I ended up in the Sheet Properties dialog box, but it's not allowing me to select sheets to modify (see attached image). I'm wondering what obscure setting I have set to the wrong option, or if I'm even on the right track to switching drawing sheet templates. Any help would be appreciated, thanks
What you need to do is open the blank drawing with the title block set up the way you want, assuming you made those changes while in "Edit sheet format" mode. Go to File > Save sheet format. Save this format in the location you're pointing to at Tools > Options > System Options > File Locations > Sheet formats. Now you should be able to open existing drawings, right-click on the sheet tab, choose Properties, and select this new sheet format. You should be able to do it for all sheets in one operation.
