4 Replies Latest reply on May 10, 2017 7:21 AM by Jaja Jojo
    SW Open Preview
    Jaja Jojo
      just recently the preview was gone and i cannot find the way to turn it back again like in the second picture
        • Re: SW Open Preview
          Josh Angell
          Hi Jaja,
          Unfortunately this could be a number of things, the first things to try are:
          1- Ensure thumbnail option is ticked in the system options
          2- Ensure Windows Folder and search options isn't set to only show icons
          3- Try different size of thumbnails
          4- Open files and rebuild and resave
            Josh Angell
            If the above are not the cause then it is likely dll that is not correctly registered or corrupt. To fix this:
            1. Run command prompt as ADMINISTRATOR Start > type CMD and  right click >  run as administrator
            2. Change directory using the command (no space before text): cd C:\Program Files\Common Files\SOLIDWORKS Shared
            3. Run the following command: regsvr32 /u  sldwinshellextu.dll
            (to unregister the dll)
            4.Run the command: regsvr32 sldwinshellextu.dll
            (to register the dll)
            5.This should say it is successfully registered.
            click "ok" at the prompt.
              Jaja Jojo
              Hi Josh, thanks for the reply
              I did try your suggestion but it didn't work, I will try to repair my intallation and if it will not ill try to undo some windows upadate
                Jaja Jojo
                I do not know what happens but after i repair installation of Solidworks, HSMworks and rollback Windows update the icon returns to normal
