there are parts inside the "tube" used for the computational domain but Solidworks says they are out of the computational domain, and they are not taken into account for the flow simulation
Usually this happens when your domain isn't actually including what you think it is. It's possible that you have leaks in your model and so Flow Sim is only considering some small cavity somewhere in your model to be the entire domain. Use the 'leak tracing' and 'check geometry' tools to see what your computational domain actually is. Personally I find the "show fluid" feature inside the 'Check Geometry' tool to be very useful for this purpose.
Actually, the problem was with the mesh : the local mesh around the flat plates has to be small enough so that the flow doesn't go through.
