Has anyone had an issue with mates getting out of whack on assemblies. I mate a part in an assembly and everything looks good, re-open the assembly later and the mates have "moved". For instance a hole to hole mate between two parts now has the holes mated to different holes. Of I will have a plate with a chamfered edge. I mate another part a distance from the vertical face of the part and when I go back in the mate is now to the mated to the angled chamfer surface? I though maybe it had to do with using parts that had imported geometry, but even creating from scratch I am still seeing issues.
My suspicion is that the parts are not fully mated in place on the assy. Then when the assy is opened, there are some assumptions being made that you are not expecting.
