I'm trying to make a sweep cut, but I can't seem to get the profile and path lined up. Profile is sketch 23 path is the helix/spiral. It doesn't show any option for a pierce relation.
I think you are doing a crossing box select. You just want the point only. If you just hover your cursor over the center of the rec you will see the point highlight. Then select it and with the control key held down select the helix.
