i have a part that has a left and right configuration, but i also need ashort and tall configuration of it too, not sure if this is possible like it was in CREO.
i am seeing an error pop up for a dangling sketch, but the feature is for another configuration and is suppressed.
If I understand you correctly, your error is coming from a sketch that belongs to a suppressed feature? If you also suppress your sketch that error should go away. You can use the same "Modify Configurations" window to suppress / unsuppress multiple features across multiple configurations using the check boxes.
Yes, you can use design table or config. dimension
