Sometimes when sketch line is used as a revolve axis it revolves and other times it produces error message. In such cases, separate revolve axis is need to fix the error. What is reason for that?
Maha,
In your first pictured example, the profile would intersect itself, which is forbidden in boss revolves. If, for example you cut the profile in half, closing it along the chosen 'rotation axis', you would get a result that completes.
In the second example, the theoretical start and end profiles in the revolve would only 'touch' once you reach a full revolution at 360, if this is desired. This is the only type of 'touching' that's really allowed in revolves.
Cheers,
Sean
You want Line2, not Line5 as your Axis of Revolution.
Curious - is your instructor not able to answer any of these questions?
