The goal is to add part numbers to the configuration properties to multiple configurations using the design table. As you can see below, I have assigned part numbers (PN1, PN 2... etc.) to each configuration. However, it doesn't seem to come through in the configuration specific tab.
What is the proper way to assign part numbers to configurations?
Hi Peter,
Your suggestion worked for me. I created a Part Number in the 'Configuration Specific' tab first and it generated a field call $PRP@PartNumber within the design table. This seems to be specificly linked to each configuration. Whereas previously the field was labelled $PARTNUMBER, which was connected to the 'Custom Configuration' tab only. Now each configuration has its own unique PartNumber and it is showing through in CADLink as well.
Problem solved.
