IKIvan Kalazic06/05/2017
Hi all.
I am working in SW 2017 at my workplace.
I am making sheet metal conic filter that looks like a pointy hat.
When i make only conical part i can get Folded sheet metal From of it. But when i add metal flange = ring part around it (base of cone- circle).....Folded pttern is impossible to achieve. I tried to do this conical sheet metal part in 2 different ways following some tutorials on the net.
As a Revolve feature drawn narrow line around a center-line and then converted to sheet metal.
As a Swept Flanges.
It should look like on the image below without plate that holds it.
I can't achieve Flat pattern from of it. This is very important to be Drawn in with correct dimensions in order to produce it.
Thank you very much for your help.
