2 Replies Latest reply on May 5, 2017 7:33 AM by Jacob Kuznicki
    (SW 2017 SP2.0)  When I try to use IExtrudeFeatureData2.LinkToThickness = True Solidworks crashes.
    Jacob Kuznicki
      (SW 2017 SP2.0)
      I am trying use the API to create a cut extrude in a sheetmetal part.  I want the cut extrude to "link to thickness".  When I try to use IExtrudeFeatureData2.LinkToThickness = True Solidworks crashes.  Is there a method that is more appropriate?
                     Dim swSheetMetal As SldWorks.SheetMetalFeatureData
                     'There is code that sets the swSheetMetal variable to the Sheetmetal feature definition
                      'Sets the thickness value of the sheet metal to a variable.
                      dblThk = swSheetMetal.Thickness
                      'Creates a Cut Extrusion (blind - link to thickness)
                      swModel.FeatureManager.FeatureCut True, False, False, 0, 0, dblThk, dblThk, False, False, False, False, 0.01745329251994, 0.01745329251994, False, False, False, False, 1, 1, 1
                      'Captures the CutExtrusion feature that was just created and links the depth dimension to the thickness of the sheet metal.
                      Set swFeature = swSelMgr.GetSelectedObject5(1)
                      Dim extFeatData As ExtrudeFeatureData2
                      Set extFeatData = swFeature.GetDefinition
                     extFeatData.LinkToThickness = True  '<<<CRASH>>>
        • Re: (SW 2017 SP2.0)  When I try to use IExtrudeFeatureData2.LinkToThickness = True Solidworks crashes.
          Peter Brinkhuis
          Could you post a more complete example of what you have? Something that works preferably (up until the crash)? I'm trying to recreate something that works now, but the error might just be in that part of the code.
              Jacob Kuznicki
              Start with a sheetmetal part (we use gage tables for thickness and bend radius).  Create a circular sketch on the face of the sheetmetal part.  Run the macro below with the sketch selected.
              Dim swFeature As SldWorks.Feature
              Dim swFeatName As String
              Dim swFeatType As String
              Dim dblThk As Double
              If Not swApp Is Nothing Then
                    Set swModel = swApp.ActiveDoc
                    If Not swModel Is Nothing Then
                        Set swFeature = swModel.FirstFeature
                          While Not swFeature Is Nothing
                              swFeatName = swFeature.Name
                              swFeatType = swFeature.GetTypeName
                              If swFeatType = "SheetMetal" Then
                                Set swSheetMetal = swFeature.GetDefinition
                                'Creates a Cut Extrusion (blind)
                                'and links the depth dimension to the thickness of the
                                'sheet metal.
                             Set swFeature = swFeature.GetNextFeature
                          Wend
                    Set swModel = Nothing
              Set swApp = Nothing
              This is where my Solidworks will crash, although the Help documentation states that LinkToThickness is a set\get property.
