Hi All,
I am trying to create a tool body to create a solid swept cut from a revolved bass/base. It is simple shape equivalent to a ball end-mill.
However when I revolve the shape there is no check box for "merge result".
I remember having this problem in the past, but I don't remember how I resolved the issue.
Any thoughts? Am I missing something obvious?
Cheers!
Hi All,
Thanks for your replies.
Here is a screenshot of the dialog, without the "merge result".
Also I have found a work-around, which Deepak provided when I encountered the same problem two years ago. I had booked marked the link and found it when I was replying to this question.
The solution was to hide the body, create the revolve, and then show the body.
That seems to do the trick, but I still don't know why the box does not appear.
I have made little test files with the same geometry but a simple rectangular extrude as a starting point and the box also does not appear.
Cheers,
Niels
