D. chorosy
Sketching in configurations
Discussion created by D. chorosy on Dec 15, 2008
Latest reply on Dec 15, 2008 by Ola Linde
I've got a sketch for a drill & tap hole and I would like to set its location from different references depending on which configuration I am.
For instance, in one configuration I want to locate the hole from the middle of part and in the 2nd config. I want to locate it from the edge of the part.
Is there a way to do so without having to create 2 different holes ( 1 in each configuration) which messes things up in the assembly?
I was thinking about having 2 dimensions and I could set one or the other to be driven depending on the configuration but this does not seem possible.
