Anyone else notice this. The "Confirm Delete" box's option for "Don't Show Again" always pops up checked. Shouldn't this be empty by default?
Especially when deleting detail views since there is a box for "Delete Detail Sketch".
2016-SP5 - But it only happens after I've deleted a few detail views. If you delete about 4~5 in a row, it will eventually pop up checked on it's own.
Ed, tried on few drawings with 2016 SP5 but not able to reproduce it. Could you please report to your VAR.
Hey Deepak,
It generally does it on section views or detail views. I get this too on 2016 SP5. I'm not sure I ever mentioned it to my VAR though.
Could be issue with registry not ouable to stick that setting. Please capture the issue using Rx tool and send to your VAR.
I'm supposed to upgrade from SolidWorks 2016 to SolidWorks 2017 within the next month or so. I'm thinking of waiting till then before sending it to my VAR in case it would be fixed in 2017.
What do you think?
I would still go ahead and report as this could be system related issue and not surely a version issue.
Hrmm, I get this bug rather often(4 to 5 times a day) but it seems to be one of those bugs that takes a certain time to activate itself.
I am currently trying to reproduce it to send it to my VAR but it just won't happen... Usually I get it by deleting a view.
Edit: Got it after a while, had to delete a few things and then when I tried to delete a sheet, it was checked by default. I will send it to my VAR when I hear back from them, hopefully they can figure it out.
Edit 2: I didn't close my session after I got the bug, I only closed the drawing. The bug is not present in another drawing. Could it be a bug that clears itself when you switch drawings..?
Works fine for me. Which version and SP you're using?
