I am using SW2014 SP5.
I would like to fillet a small step / jog. The diameter of the fillets is larger than the step. because of this I can't seem to get the fillet tool to create the two fillets. See the attached image to understand the resultant "S" shape of the two tangent fillets I would like to create.
This is easy enough to create manually. But I would like to use the fillet tool.
Daen
Message was edited by: Daen Hendrickson Solution example file attached (in SW2014 format)
Inquiring minds just got to know. If you use the FeatureXpert does that not give you a true tangent s curve?
