We can split a line in 2D sketch.
Can we split face edge?
Example:
we make Planar Surface for a circle. It has one edge border.
If sketch contour is no "equivalent to the circle" Planar Surface may have 2 and more edges.
But can we make a planar circular surface with 2 edges? (or better split edges when ever we need)
Thank you !
As Jim Steinmeyer says, you should be able to accomplish what you need using the split line feature:
Basically, it will split the surface into 2 surfaces, which will also neatly result in 2 edges.
Hope that works for you.
