Hello!
In 2D sketch we can make spline handle perpendicular to a line.
Why we can not make 3D spline handle normal to a plane? But we make line normal to a plane and then set spline handle parallel to this line.
Hello!
Thank you Paul, but why you are talking about some failure, was a such functionality before?
I just wonder about how other make a spline normal to a plane.
Ivan... I'm complaining about something similar... where the contraints menu flickers off/on when making a selection.
Anyhow.. .for your problem.. I'd suggest.. .while in 3dSketch.. make a construction line perpendicular to the plane.. and then apply your spline that line and make it tangent. (image attached)
Ivan... I've witnessed this same behavior using 2016 and 2017... and 2017 is probably the worse.... I get a flickered window,.. and sometimes I can see some of the menu/window but, they are gone!?
The GUI Team has failed again.. sorry to be crass, but honestly,.. SW Corp are NOT addressing these issues.
