Hi everyone,
I'm trying to make a drawing of a large weldment. I have several sheets for detail views of specific components of the weldment. To make these detail views I have used configurations and several "Delete Body" features so that each configuration will only show the bodies I'm interested when I add them to a drawing view. The only way I have to identify where each detail view belongs in the major weldment drawing is by using cut list numbers. I was hoping that I could add a cut list to each detail view, and the item number would appear as the same item number that it did in the first sheet. Instead, the weldment starts over from 1. Is there any way around this behavior?
Thanks in advance for the help
If you right click on the views and select properties, there's an option to link it to a table. Select your cultist table from there, I've not tried it with configurations, not sure how they will affect it.
