PROBLEM WITH MACRO TO CREATE MOVEFACE(ROTATION) AND AFTER ROTATE THIS MOVE FACE
Question asked by Korbi Anis on May 1, 2017
Hello my friends . I hae a problem and I need your help ! I am beginner with VBA solidwroks and I tried to write a macro to insert move face by rotation angle in part and After try to rotate this move face. but It does not work especiaaly in  [ SUB MOVEFACE() ].thanks a lot
Dim swModelDocExt As SldWorks.ModelDocExtension
Dim swFeat As SldWorks.Feature
Dim swMoveFaceFeatData As SldWorks.MoveFaceFeatureData
Dim varPara As Variant
Dim newPara(5) As Double
Dim newVarPara As Variant
Dim boolstatus As Boolean
Dim PI As Double
Dim i As Long
Dim swFeatMgr As SldWorks.FeatureManager
moveface
rotatemoveface
Sub moveface()
    Set swModel = swApp.ActiveDoc
    Set swModelDocExt = swModel.Extension
    Set swFeatMgr = swModel.FeatureManager
boolstatus = swModelDocExt.SelectByID2("", "FACE", -5.14647149738039E-02, 7.74281150177103E-03, 2.45759830993393E-02, False, 1, Nothing, 0)
Set swFeat = swFeatMgr.InsertMoveFace(1, False, 0, 0.05)
    swModel.ViewZoomtofit2
Sub rotatemoveface()
' Set PI
PI = 4 * Atn(1)
' Select, get, and access Move Face feature
boolstatus = swModelDocExt.SelectByID2("Move Face1", "BODYFEATURE", 0, 0, 0, False, 0, Nothing, 0)
Set swFeat = swSelMgr.GetSelectedObject6(1, -1)
Set swMoveFaceFeatData = swFeat.GetDefinition
swMoveFaceFeatData.AccessSelections swModel, Nothing
' Get current XYZ origin and rotation angles of Move Face feature
Debug.Print "Before rotating Move Face feature..."
' 1 radian = 180º/p = 57.295779513º or approximately 57.3º
Debug.Print "  Draft angle of Move Face feature: " & swMoveFaceFeatData.Angle * 57.3 & " degrees"
Debug.Print "  XYZ origin (first 3) and rotation angles (last 3)"
varPara = swMoveFaceFeatData.TriadRotationParameters
For i = LBound(varPara) To UBound(varPara)
    Debug.Print "    " & (varPara(i))
Next i
' New XYZ location and rotation angles for Move Face feature
newPara(0) = 0#
newPara(1) = 0#
newPara(2) = 0#
newPara(3) = 0 ' Convert radians to degrees
newPara(4) = 2 * PI / 180 ' Convert radians to degrees
newPara(5) = 0#
newVarPara = newPara
' Rotate the Move Face feature
swMoveFaceFeatData.TriadRotationParameters = newVarPara
Debug.Print " "
Debug.Print "After rotating Move Face feature..."
newVarPara = swMoveFaceFeatData.TriadRotationParameters
For i = LBound(newVarPara) To UBound(newVarPara)
    Debug.Print "    " & (newVarPara(i))
Next i
' Modify the Move Face feature
swFeat.ModifyDefinition swMoveFaceFeatData, swModel, Nothing
