Hi all,
I have a drawing that I can not for the life of me get the hidden edges to show from a particular part. I have other drawings with just as much detail that it works, but for some reason its not working on this one drawing, is there some setting for each drawing.
Well I just figured it out so guess I will share as I couldn't find it on this site or the web:
Under the display state was a check for "High Quality" the option disappeared when I selected so no idea on how to get to the option once you set it, but check this per view if you have the issue. And the hidden edges now show.
Good to answer your own question half way thru writing a complaint about it LOL
Cheers,
I'm having same problem here. It must be a moderately recent windows update patch that caused this, because I've been having it for a couple of weeks, and my co-worker is now experiencing it since I ran Update on his PC.
We tried your solution, and it did not work, at least initially. I'll try to see if it improves.
My solution was more of a PITA. I created a sketch in the part to include the hidden edges I wanted to show, when Converted Entities in the drawing from the sketch onto the sheet as a hidden line Layer. It was tedious, and once I was completed with my drawing, ultimately unnecessary. That's because, although it would not show me the hidden lines on the view on monitor, it still produced them in the Save_As Adobe PDF result.
It appears inconsistent in its error and its fix. (Edit: I summarized this above as "same problem". This means 2016 SP3 as well. I neglected to make this clear.)
