My photo view 360 render from my uni work has turned out blurry I have attached an image of the preview, any ideas what is wrong?
Hi Harry,
Have you turned direct caustics on? If so, try turning it off.
EDIT:
Also, if you're using textured appearances? be sure to scale them correctly. Turn advanced on at the top of the appearance dialog, then mapping and knock the size down. Do this with the preview window open to get live updates.
It looks like you're in the preview window which is set to Good. Have you done a Final Render yet?
Steve C
Change your settings here
