0 Replies Latest reply on Apr 27, 2017 3:41 PM by Paul Kurowski
    Hyper-elastic material constants may be calculated from material curves; uo t three different material curves may be used (simple tension, 2D tension and bi-axial). Are the results somewhow avaraged between different curves to produce just one set of mate
    Paul Kurowski
      Hyper-elastic material constants may be calculated from material curves; up to three different material curves may be used (simple tension, 2D tension and bi-axial) but even one curve is sufficient to find material constants. If more than one curve is used, are the results somehow averaged between different curves to produce just one set of material constants?
      Paul Kurowski
