23 Replies Latest reply on Jan 17, 2018 11:19 AM by Doug Foote
    DraftSight 2017 crashing on launch
    Ron Flynn
      I have installed DraftSight 2017 and it keeps crashing on launching. I get:
      DraftSight Alert. Any suggestions?
        • Re: DraftSight 2017 crashing on launch
          Bob Van Dick
          Ron,
          I believe there was a hotfix regarding Draft Sight awhile back.  Did you install that?
          Bob
            Ron Flynn
            I don't believe the hotfix is required for 2017. I have successfully upgraded 20 other clients so I'm not sure why this one keeps crashing. I uninstalled and re-installed and still the same DraftSight Alert message.
              Rick McDonald
              Draftsight  2017 (sp0) REQUIRES the hotfix.
              Draftsight 2017 SP1 Includes the hot fix so it is not needed.
              What version did you install? If it was 2017 sp0, I suggest you download and install the 2017 SP1 version and try again.
              I ran 2016 for a few months without noticeable issues without the Hot Fix - then I did something and it crashed, That's when I discovered the hotfix and installed it and it solved my problem (don't remember what the problem was), Then I had other issues with my printer and decided to update to 2017 sp1 (which had then just come out) and now am running fine.
              A co-worker was running 2016 and last week hit a weird problem where his 2D file views in Windows Explorer were no longer showing up and he installed the 2017 sp1 and it fixed that (may have not been related to the hotfix - probably some other glitch) - but he did a full uninstall and reinstall and it corrected his view problem.
                Denis Denis
                Even in my company we have the same problem on a user's pc, the error message is the same.
                We tried a bit of everything, reinstalled the program, changed version, launched hotfix, modified the registry but nothing, always the same identical error and, in some cases, even locks on the activation request.
                Sometimes a crash report came out (which in turn crashed without making me read anything), I managed to retrieve it in the dassault folder:
                ____#######____#######____#######____#######____#######
                Document_2
                File Name : NONAME_0
                File Path : C:/Program Files/Dassault Systemes/DraftSight/bin/NONAME_0.dwg
                File Extension : dwg
                File Version: R27 (2013) release [31]
                File SavedByVersion:  [0]
                File Size : 0 MB
                Was Active : True
                History :
                _DOCINIT
                42
                -1
                0
                -1
                0
                C:\Users\avita01\AppData\Roaming\DraftSight\12.1.2\Template\standard.dwt
                _MAINSELECT
                -2.4887,7.2062,0.0000
                ^C
                _OPEN
                gl_info
                OpenGL Information:
                Vendor - Intel
                Renderer - Intel(R) HD Graphics 520
                Version - 4.4.0 - Build 21.20.16.4627
                Max texture size - 16384
                Max view size - 16384 x 16384
                Max vertices/indices - 1048576/1048576
                Display monitors count - 1
                Primary display monitor resolution - 1920 x 1080
                Virtual screen resolution - 1920 x 1080
                OpenGL ICD:
                Failed to retrieve ICD.
                DriverIssues:
                Black=0
                NoXOR=0
                BackB=0
                Intel=0
                IAtom=0
                IMonoTex=0
                IMaxFloat=0
                OpenGL extensions:
                GL_3DFX_texture_compression_FXT1
                GL_AMD_depth_clamp_separate
                GL_AMD_vertex_shader_layer
                GL_AMD_vertex_shader_viewport_index
                GL_ARB_ES2_compatibility
                GL_ARB_ES3_compatibility
                GL_ARB_arrays_of_arrays
                GL_ARB_base_instance
                GL_ARB_blend_func_extended
                GL_ARB_buffer_storage
                GL_ARB_cl_event
                GL_ARB_clear_buffer_object
                GL_ARB_clear_texture
                GL_ARB_clip_control
                GL_ARB_color_buffer_float
                GL_ARB_compatibility
                GL_ARB_compressed_texture_pixel_storage
                GL_ARB_compute_shader
                GL_ARB_conservative_depth
                GL_ARB_copy_buffer
                GL_ARB_copy_image
                GL_ARB_debug_output
                GL_ARB_depth_buffer_float
                GL_ARB_depth_clamp
                GL_ARB_depth_texture
                GL_ARB_derivative_control
                GL_ARB_draw_buffers
                GL_ARB_draw_buffers_blend
                GL_ARB_draw_elements_base_vertex
                GL_ARB_draw_indirect
                GL_ARB_draw_instanced
                GL_ARB_enhanced_layouts
                GL_ARB_explicit_attrib_location
                GL_ARB_explicit_uniform_location
                GL_ARB_fragment_coord_conventions
                GL_ARB_fragment_layer_viewport
                GL_ARB_fragment_program
                GL_ARB_fragment_program_shadow
                GL_ARB_fragment_shader
                GL_ARB_fragment_shader_interlock
                GL_ARB_framebuffer_no_attachments
                GL_ARB_framebuffer_object
                GL_ARB_framebuffer_sRGB
                GL_ARB_geometry_shader4
                GL_ARB_get_program_binary
                GL_ARB_gpu_shader5
                GL_ARB_gpu_shader_fp64
                GL_ARB_half_float_pixel
                GL_ARB_half_float_vertex
                GL_ARB_indirect_parameters
                GL_ARB_instanced_arrays
                GL_ARB_internalformat_query
                GL_ARB_internalformat_query2
                GL_ARB_invalidate_subdata
                GL_ARB_map_buffer_alignment
                GL_ARB_map_buffer_range
                GL_ARB_multi_bind
                GL_ARB_multi_draw_indirect
                GL_ARB_multisample
                GL_ARB_multitexture
                GL_ARB_occlusion_query
                GL_ARB_occlusion_query2
                GL_ARB_pixel_buffer_object
                GL_ARB_point_parameters
                GL_ARB_point_sprite
                GL_ARB_post_depth_coverage
                GL_ARB_program_interface_query
                GL_ARB_provoking_vertex
                GL_ARB_query_buffer_object
                GL_ARB_robust_buffer_access_behavior
                GL_ARB_robustness
                GL_ARB_robustness_isolation
                GL_ARB_sample_shading
                GL_ARB_sampler_objects
                GL_ARB_seamless_cube_map
                GL_ARB_seamless_cubemap_per_texture
                GL_ARB_separate_shader_objects
                GL_ARB_shader_atomic_counters
                GL_ARB_shader_bit_encoding
                GL_ARB_shader_draw_parameters
                GL_ARB_shader_image_load_store
                GL_ARB_shader_image_size
                GL_ARB_shader_objects
                GL_ARB_shader_precision
                GL_ARB_shader_stencil_export
                GL_ARB_shader_storage_buffer_object
                GL_ARB_shader_subroutine
                GL_ARB_shading_language_100
                GL_ARB_shading_language_420pack
                GL_ARB_shading_language_packing
                GL_ARB_shadow
                GL_ARB_stencil_texturing
                GL_ARB_sync
                GL_ARB_tessellation_shader
                GL_ARB_texture_barrier
                GL_ARB_texture_border_clamp
                GL_ARB_texture_buffer_object_rgb32
                GL_ARB_texture_buffer_range
                GL_ARB_texture_compression
                GL_ARB_texture_compression_bptc
                GL_ARB_texture_compression_rgtc
                GL_ARB_texture_cube_map
                GL_ARB_texture_cube_map_array
                GL_ARB_texture_env_add
                GL_ARB_texture_env_combine
                GL_ARB_texture_env_crossbar
                GL_ARB_texture_env_dot3
                GL_ARB_texture_float
                GL_ARB_texture_gather
                GL_ARB_texture_mirror_clamp_to_edge
                GL_ARB_texture_mirrored_repeat
                GL_ARB_texture_multisample
                GL_ARB_texture_non_power_of_two
                GL_ARB_texture_query_levels
                GL_ARB_texture_query_lod
                GL_ARB_texture_rectangle
                GL_ARB_texture_rg
                GL_ARB_texture_rgb10_a2ui
                GL_ARB_texture_stencil8
                GL_ARB_texture_storage
                GL_ARB_texture_storage_multisample
                GL_ARB_texture_swizzle
                GL_ARB_texture_view
                GL_ARB_timer_query
                GL_ARB_transform_feedback2
                GL_ARB_transform_feedback3
                GL_ARB_transform_feedback_instanced
                GL_ARB_transpose_matrix
                GL_ARB_uniform_buffer_object
                GL_ARB_vertex_array_bgra
                GL_ARB_vertex_array_object
                GL_ARB_vertex_attrib_64bit
                GL_ARB_vertex_attrib_binding
                GL_ARB_vertex_buffer_object
                GL_ARB_vertex_program
                GL_ARB_vertex_shader
                GL_ARB_vertex_type_10f_11f_11f_rev
                GL_ARB_vertex_type_2_10_10_10_rev
                GL_ARB_viewport_array
                GL_ARB_window_pos
                GL_ATI_separate_stencil
                GL_EXT_abgr
                GL_EXT_bgra
                GL_EXT_blend_color
                GL_EXT_blend_equation_separate
                GL_EXT_blend_func_separate
                GL_EXT_blend_minmax
                GL_EXT_blend_subtract
                GL_EXT_clip_volume_hint
                GL_EXT_compiled_vertex_array
                GL_EXT_direct_state_access
                GL_EXT_draw_buffers2
                GL_EXT_draw_range_elements
                GL_EXT_fog_coord
                GL_EXT_framebuffer_blit
                GL_EXT_framebuffer_multisample
                GL_EXT_framebuffer_object
                GL_EXT_geometry_shader4
                GL_EXT_gpu_program_parameters
                GL_EXT_gpu_shader4
                GL_EXT_multi_draw_arrays
                GL_EXT_packed_depth_stencil
                GL_EXT_packed_float
                GL_EXT_packed_pixels
                GL_EXT_polygon_offset_clamp
                GL_EXT_rescale_normal
                GL_EXT_secondary_color
                GL_EXT_separate_specular_color
                GL_EXT_shader_framebuffer_fetch
                GL_EXT_shader_integer_mix
                GL_EXT_shadow_funcs
                GL_EXT_stencil_two_side
                GL_EXT_stencil_wrap
                GL_EXT_texture3D
                GL_EXT_texture_array
                GL_EXT_texture_compression_s3tc
                GL_EXT_texture_edge_clamp
                GL_EXT_texture_env_add
                GL_EXT_texture_env_combine
                GL_EXT_texture_filter_anisotropic
                GL_EXT_texture_integer
                GL_EXT_texture_lod_bias
                GL_EXT_texture_rectangle
                GL_EXT_texture_sRGB
                GL_EXT_texture_sRGB_decode
                GL_EXT_texture_shared_exponent
                GL_EXT_texture_snorm
                GL_EXT_texture_storage
                GL_EXT_texture_swizzle
                GL_EXT_timer_query
                GL_EXT_transform_feedback
                GL_IBM_texture_mirrored_repeat
                GL_INTEL_conservative_rasterization
                GL_INTEL_fragment_shader_ordering
                GL_INTEL_framebuffer_CMAA
                GL_INTEL_map_texture
                GL_INTEL_multi_rate_fragment_shader
                GL_INTEL_performance_query
                GL_KHR_blend_equation_advanced
                GL_KHR_blend_equation_advanced_coherent
                GL_KHR_debug
                GL_KHR_texture_compression_astc_hdr
                GL_KHR_texture_compression_astc_ldr
                GL_NV_blend_square
                GL_NV_conditional_render
                GL_NV_primitive_restart
                GL_NV_texgen_reflection
                GL_SGIS_generate_mipmap
                GL_SGIS_texture_edge_clamp
                GL_SGIS_texture_lod
                GL_SUN_multi_draw_arrays
                GL_WIN_swap_hint
                printer_info
                Printer Name : SYS - XPS
                Driver Name : Microsoft XPS Document Writer v4
                Attributtes: 576
                Capabilities: [Copies,Collation,Unknown]
                ConfigManagerErrorCode : NULL
                CurrentCharSet : NULL
                CurrentPaperType : NULL
                CurrentLanguage : NULL
                Default: False
                DefaultCapabilities : NULL
                DefaultLanguage : NULL
                DefaultPaperType : NULL
                DetectedErrorState: 0
                ErrorCleared : NULL
                ErrorDescription : NULL
                ErrorInformation : NULL
                ExtendedDetectedErrorState: 0
                ExtendedPrinterStatus: 2
                HorizontalResolution: 600
                LastErrorCode : NULL
                Local: True
                MaxSizeSupported : NULL
                Network: False
                PaperSizesSupported: [Letter,Other,Legal,Other,A4,A5,JIS B6,Other,Other,NA-Number-9-Envelope,Other,Other,D,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,A7,Unknown,Unknown,Unknown,Unknown,Unknown]
                PrinterPaperNames: [Letter,Letter Small,Tabloid,Ledger,Legal,Statement,Executive,A3,A4,A4 Small,A5,B4 (JIS),B5 (JIS),Folio,Quarto,10×14,11×17,Note,Envelope #9,Envelope #10,Envelope #11,Envelope #12,Envelope #14,C size sheet,D size sheet,E size sheet,Envelope DL,Envelope C5,Envelope C3,Envelope C4,Envelope C6,Envelope C65,Envelope B4,Envelope B5,Envelope B6,Envelope,Envelope Monarch,6 3/4 Envelope,US Std Fanfold,German Std Fanfold,German Legal Fanfold,B4 (ISO),Japanese Postcard,9×11,10×11,15×11,Envelope Invite,Letter Extra,Legal Extra,A4 Extra,Letter Transverse,A4 Transverse,Letter Extra Transverse,Super A,Super B,Letter Plus,A4 Plus,A5 Transverse,B5 (JIS) Transverse,A3 Extra,A5 Extra,B5 (ISO) Extra,A2,A3 Transverse,A3 Extra Transverse,Japanese Double Postcard,A6,Japanese Envelope Kaku #2,Japanese Envelope Kaku #3,Japanese Envelope Chou #3,Japanese Envelope Chou #4,Letter Rotated,A3 Rotated,A4 Rotated,A5 Rotated,B4 (JIS) Rotated,B5 (JIS) Rotated,Japanese Postcard Rotated,Double Japan Postcard Rotated,A6 Rotated,Japan Envelope Kaku #2 Rotated,Japan Envelope Kaku #3 Rotated,Japan Envelope Chou #3 Rotated,Japan Envelope Chou #4 Rotated,B6 (JIS),B6 (JIS) Rotated,12×11,Japan Envelope You #4,Japan Envelope You #4 Rotated,PRC Envelope #1,PRC Envelope #3,PRC Envelope #4,PRC Envelope #5,PRC Envelope #6,PRC Envelope #7,PRC Envelope #8,PRC Envelope #9,PRC Envelope #10,PRC Envelope #1 Rotated,PRC Envelope #3 Rotated,PRC Envelope #4 Rotated,PRC Envelope #5 Rotated,PRC Envelope #6 Rotated,PRC Envelope #7 Rotated,PRC Envelope #8 Rotated,PRC Envelope #9 Rotated,User Defined Size]
                PrinterState: 0
                Printer Name : SYS - Send To OneNote 2016
                Driver Name : Send to Microsoft OneNote 16 Driver
                Attributtes: 576
                Capabilities: [Copies,Unknown]
                Default: False
                ErrorCleared : NULL
                Local: True
                Network: False
                PaperSizesSupported: [Letter,Legal,A3,JIS B5,NA-Number-10-Envelope,Unknown,Unknown,Unknown,Unknown,Unknown]
                PrinterPaperNames: [Letter,Tabloid,Legal,Executive,A3,A4,B4 (JIS),B5 (JIS),Envelope #10,Envelope Monarch]
                PrinterState: 0
                Printer Name : SYS - PDF
                Driver Name : Microsoft Print To PDF
                Attributtes: 576
                Default: False
                ErrorCleared : NULL
                Local: True
                Network: False
                PaperSizesSupported: [Letter,Legal,Other,A4,JIS B5,Unknown,Unknown,Unknown,Unknown,Unknown]
                PrinterPaperNames: [Letter,Tabloid,Legal,Statement,Executive,A3,A4,A5,B4 (JIS),B5 (JIS)]
                PrinterState: 0
                Printer Name : NMMFP002 - Kyocera TASKalfa 3051ci XPS
                Driver Name : Kyocera TASKalfa 3051ci XPS
                Attributtes: 580
                Capabilities: [Copies,Duplex Printing,Unknown,Unknown]
                Default: True
                ErrorCleared : NULL
                Local: True
                Network: False
                PaperSizesSupported: [Letter,Other,A3,A5,JIS B6,NA-Number-9-Envelope,Other,Other,Other,Other,Other,Other,Other,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown]
                PrinterPaperNames: [Letter,Legal,Statement,Executive,A3,A4,A5,B4 (JIS),B5 (JIS),Folio,Envelope #9,Envelope #10,Envelope DL,Envelope C5,Envelope C4,Envelope B5,Envelope Monarch,6 3/4 Envelope,A6,B6 (JIS),Ledger (11 x 17 inch),Oficio II (8.5 x 13inch),8K,16K,User Defined Size]
                PrinterState: 0
                Printer Name : Microsoft XPS Document Writer
                Attributtes: 576
                Default: False
                ErrorCleared : NULL
                Local: True
                Network: False
                PaperSizesSupported: [Letter,Other,Legal,Other,A4,A5,JIS B6,Other,Other,NA-Number-9-Envelope,Other,Other,D,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown]
                PrinterState: 0
                Printer Name : Microsoft Print to PDF
                Attributtes: 576
                Default: False
                ErrorCleared : NULL
                Local: True
                Network: False
                PrinterState: 0
                Printer Name : Fax
                Driver Name : Microsoft Shared Fax Driver
                Attributtes: 16448
                Capabilities: [Color Printing,Unknown]
                Default: False
                ErrorCleared : NULL
                HorizontalResolution: 200
                Local: True
                Network: False
                PaperSizesSupported: [Letter,Legal,Other,Other,JIS B6,Other,NA-Number-9-Envelope,Other,Other,Other,Other,Other,Other,Other,Other,Unknown,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Other,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown,A2,A7,Unknown,Unknown,Unknown,Unknown,Unknown,Unknown]
                PrinterPaperNames: [Letter,Letter Small,Legal,Statement,Executive,A4,A4 Small,A5,B5 (JIS),Folio,Quarto,Note,Envelope #9,Envelope #10,Envelope #11,Envelope #12,Envelope #14,Envelope DL,Envelope C5,Envelope C6,Envelope C65,Envelope B5,Envelope B6,Envelope,Envelope Monarch,6 3/4 Envelope,German Std Fanfold,German Legal Fanfold,Japanese Postcard,Reserved48,Reserved49,Letter Transverse,A4 Transverse,Letter Plus,A4 Plus,A5 Transverse,B5 (JIS) Transverse,A5 Extra,B5 (ISO) Extra,Japanese Double Postcard,A6,Japanese Envelope Kaku #3,Japanese Envelope Chou #3,Japanese Envelope Chou #4,A5 Rotated,Japanese Postcard Rotated,Double Japan Postcard Rotated,A6 Rotated,Japan Envelope Chou #4 Rotated,B6 (JIS),B6 (JIS) Rotated,Japan Envelope You #4,PRC 16K,PRC 32K,PRC 32K(Big),PRC Envelope #1,PRC Envelope #2,PRC Envelope #3,PRC Envelope #4,PRC Envelope #5,PRC Envelope #6,PRC Envelope #7,PRC Envelope #8,PRC 32K Rotated,PRC 32K(Big) Rotated,PRC Envelope #1 Rotated,PRC Envelope #2 Rotated,PRC Envelope #3 Rotated,PRC Envelope #4 Rotated,Oficio II (8.5 x 13inch),16K]
                PrinterState: 0
                variables
                System locale: en_US
                LANGUAGE = 0
                DEBUGMODE = 8192
                DISPLAYOPTIONS = 0
                DEVOPTIONS = 1
                win_info
                Name : Microsoft Windows 10 Pro
                Version : 10.0.15063
                OSArchitecture : 64-bit
                CSDVersion : NULL
                CodeSet : 1252
                FreePhysicalMemory : 4.38001 GB
                FreeVirtualMemory : 5.22063 GB
                LastBootUpTime : 20170516160939.485559+120
                LocalDateTime : 20170516163020.760000+120
                Locale : 0409
                TotalVirtualMemorySize : 9.1357 GB
                TotalVisibleMemorySize : 7.8857 GB
                  Dusan Ryu
                  I had the same problem too.
                  I'm using 2017 sp2.
                  I suggest changing the drawing file location in the 'Option' menu.
                  I solved it that way.
                      Rick McDonald
                      Please confirm that this is the location that you changed.
                      Were you using the default location (this is what came up on mine) when you had problems and now you changed to a different location and it is fixed?
                      What location did you change it to - just another valid location on your drive?
                      I don't have the problem on my computer (here or at home) but I am also still on SP1 and have been waiting for this bug to be fixed or a valid workaround.
                      Sounds like you found a work around - I just want to see it is stable before I upgrade.
                          Dusan Ryu
                          I don't remember exact path before used.
                          I was using default location when I have problem. Maybe it was that location you wrote.
                          I changed to 'c:\work\drawing\'(my work directory)
                          and trouble is gone.
                              Jeff Rensing
                              I am having the same issue.  Draftsight always crashes on start up and  I cannot access the options menu because of this.  If this the issue is there a file I can edit or should I just create the directory in the computer if this is the default?
                                  Rick McDonald
                                  Jeff,
                                  A few things to do and try:
                                  I is looking like (from previous posts) it may be some administrator rights settings that are the major cause.
                                  First try changing the settings for The Draftsight.exe file:
                                  Right click on the launching icon on your desktop or start menu - look in the "Start In" field for the location of the Draftsight.exe file.
                                  Open Windows Explorer and go to that location (Probably "C:\Program Files\Dassault Systemes\DraftSight\bin\").
                                  Find the Draftsight.exe file  and RIGHT CLICK" on it.
                                  Select Properties from the pull down list.
                                  In the box that opens, select the "Compatibility" tab.
                                  near the bottom - check the box for "Run ...as administrator"
                                  Click OK
                                  _______________________________________
                                  If you can not get to this box it may be that you do not have administrator rights to this location.
                                  If you can not access the directory then you may have your settings to hide hidden folders.
                                  Click on the Windows Explorer Tools menu item, Then in the Folder Options select the View tab and scroll down and select the "Show hidden Files, folders or drives"
                                  Then OK and try the above changes for the Draftsight Administrator rights settings above.
                                  If you can not get to these screens and you are on a company computer or network setup - you may not have administrator privileges and you should get someone from your IT group to set this up for you.
                                  Let us know if this does or doesn't work for you.
                                      Martial Baechler
                                      I tried this, but without success. I already have full powers being IT Manager.
                                        Jeff Rensing
                                        Still having the same issues.  We are having our IT people look into this but they have not found a solution yet. I also have full Administrator rights on the computer
                                            Rick McDonald
                                            Have you seen Jackie Yips reply at 4:42pm on Thursday 6/29 on the related thread draftsight 2017 activation
                                            This may help.
                                                Rick McDonald
                                                It looks like things are improving (Hopefully fixed).
                                                I have been communicating with some the of the Draftsight R&D team, sending them information on my systems and the failed attempts to register.  They have been making improvements on the server to better handle the busy traffic on it.
                                                I was told (Friday) to completely uninstall Draftsight and then reinstall.
                                                (I am using the free version).
                                                I tried this last night on my home computer and after re-installing I was able to activate with no problems. I also realized the new Draftsight 2018 SP0 was released and I downloaded and installed it with no issues.
                                                I then - this morning - did the same on my work computer (which would also not allow me to register).  It also worked fine (un-installed and then reinstalled (same version 2017 SP3).  After that was successful, I upgraded it to Draftsight 2018 SP0 with no issues.
                                                It told me in the last dialog box at the end of the activation process complete the activation using the activation link contained in the email (sent to my activation email address) but I never got an email and it immediately opened - I was activated.
                                                Same thing happened on my work computer.
                                                Everyone that was having problems should give this (un-install and re-install) a try and see if this fixes the problem.
                                                I am going to copy this information to some of the other posts of the Draftsight activation problems so there will be some user feedback to see if it has fully fixed the activation problem.
                                                Also posted a copy of this message on the following sites:
                                    Vishnu Vardhan
                                    I tried upgrading the graphic drivers and worked fine in the first shot.
                                      Doug Foote
                                      Uncertain if anyone is still having this issue but I have found a consistent fix.   I have done all the mentioned changes and only a very small percentage of Draftsight installs work afterwards.  However, this one fix, works 100% of the time thus far.
                                      Cause: Shared Resources.  If any DWG,DXF or even a DWF viewer is installed on the PC Prior to installing Draftsight, the crashes will occur.
                                      Fix:
                                      1) Remove all viewers of DWG, DXF and DWF viewers
                                      2) Verify Draftsight works.   If it does NOT work, Remove all "Design Suite" Installations of AutoDesk Products.  The design suites incorporate the viewing resources directly.
                                      3) Reinstall the viewers if needed.   Once Draftsight opens and has registered the resource only then can it be shared.
                                      Good Luck!
