Hi all, How do you put multiple angle dimensions into a 3D sketch? I have one line along the x axis with another line from the end point of that line running on the XY plane at 45 deg from x. Now I need to also have that same line at 30 deg from the y axis on the YZ plane. I see no provisions for adding this dimension as in there is nothing to dimension from nor will SW allow adding angle relations to say the front plane to the line. The SW help seems to assume one will only want to draw on XY plane etc instead of the line going off in 3D space.
I would control it using construction lines like shown in the pic below and dimensioning to them. File attached (SW15) as well for your reference.
Chris
