I made a rolled angle from the "structural member" now I need to flatten it to show the stock size. I can't seem to get it to flatten when inserting a bend. I have been able to do this with other "structural members" though. See image below.
SW has trouble with flattening flanges off of a curved surface, which is about exactly what you have here. I know a coworker kept on trying to find ways, and never really made any progress as far as I know. Closest he came was by using two separated configurations.
If you really need to flatten it, can you change it into two parts instead of one piece?
Did you try the Flex Feature?
If you use the Sheet Metal commands then use the Swept Flange Feature, however you will need to draw it without the internal radius that is shown. You can add this later for a visual, but sheet metal needs equal thickness.
