I tried to record a macro for changing the part appearance. However, the code does not show anything regarding the change. Does anyone have any example (e.g. change RGB and change the transparent)
Thank
Thank
Sure, see the code - just set the number of RGB
Set swModelDoc = swApp.ActiveDoc
Set swPart = swModelDoc
vMatProps = swPart.MaterialPropertyValues
'Define the RGB values (1 = RGB value 255)
vMatProps(0) = 154 / 255 'R
vMatProps(1) = 155 / 255 'G
vMatProps(2) = 156 / 255 'B
swPart.MaterialPropertyValues = vMatProps
swModelDoc.GraphicsRedraw2
swModelDoc.Save3 swSaveAsOptions_Silent, nErrors, nWarnings
Hello, I'm having trouble with the last line:
and I think without it doesn't save the appearance settings. While it does change the appearance of the part, if you go into the appearance values, nothing is different.
What's the trouble?
Hi Christian,
I get a
Run-time error '13':
Type mismatch
The debugger highlights that line as the problem.
Sure! Just so you know whats going on, the Macro takes 2 3d sketches and lofts then together to form a box. Then the appearance is changed at the bottom. Its just a rough draft for now so it looks sloppy but you get the point.
Thanks for your help
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Dim swSaveAsOptions_Silent As Integer
Dim Errors As Integer
Dim Warnings As Integer
Dim Save As Boolean
Set Part = swApp.ActiveDoc
Set myModelView = Part.ActiveView
myModelView.FrameState = swWindowState_e.swWindowMaximized
boolstatus = Part.Extension.SelectByID2("Part Box Top", "SKETCH", 0, 0, 0, True, 0, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("Part Box Bottom", "SKETCH", 0, 0, 0, True, 0, Nothing, 0)
Part.ClearSelection2 True
boolstatus = Part.Extension.SelectByID2("Part Box Top", "SKETCH", 0.2413, 6.35000000000003E-03, 0.25654, False, 1, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("Part Box Bottom", "SKETCH", 0.2413, 6.35000000000003E-03, 0.20066, True, 1, Nothing, 0)
Part.FeatureManager.InsertProtrusionBlend False, True, False, 1, 0, 0, 1, 1, True, True, False, 0, 0, 0, False, True, True
boolstatus = Part.Extension.SelectByID2("Stock", "BODYFEATURE", 0, 0, 0, False, 0, Nothing, 0)
boolstatus = Part.SelectedFeatureProperties(0, 0, 0, 0, 0, 0, 0, 1, 0, "Stock")
vMatProps = Part.MaterialPropertyValues
vMatProps(0) = 39 / 255
vMatProps(1) = 158 / 255
vMatProps(2) = 255 / 255
vMatProps(7) = 0.65
swModelDoc.Save3 swSaveAsOptions_Silent, Errors, Warnings
I changed some of the lines. Try and let me know
'Dim swApp As Object
Dim swApp As SldWorks.SldWorks ' Christian
Dim part As Object
Dim swModelDoc As SldWorks.ModelDoc2 ' Christian
Dim Errors As Long ' Integer Christian
Dim Warnings As Long ' Integer Christian
Dim Save As Boolean
'Set part = swApp.ActiveDoc
Set part = swModelDoc ' Christian
Set myModelView = part.ActiveView
boolstatus = part.Extension.SelectByID2("Part Box Top", "SKETCH", 0, 0, 0, True, 0, Nothing, 0)
boolstatus = part.Extension.SelectByID2("Part Box Bottom", "SKETCH", 0, 0, 0, True, 0, Nothing, 0)
part.ClearSelection2 True
boolstatus = part.Extension.SelectByID2("Part Box Top", "SKETCH", 0.2413, 6.35000000000003E-03, 0.25654, False, 1, Nothing, 0)
boolstatus = part.Extension.SelectByID2("Part Box Bottom", "SKETCH", 0.2413, 6.35000000000003E-03, 0.20066, True, 1, Nothing, 0)
part.FeatureManager.InsertProtrusionBlend False, True, False, 1, 0, 0, 1, 1, True, True, False, 0, 0, 0, False, True, True
boolstatus = part.Extension.SelectByID2("Stock", "BODYFEATURE", 0, 0, 0, False, 0, Nothing, 0)
boolstatus = part.SelectedFeatureProperties(0, 0, 0, 0, 0, 0, 0, 1, 0, "Stock")
vMatProps = part.MaterialPropertyValues
vMatProps(7) = 0.65
part.MaterialPropertyValues = vMatProps
