Hi all
Im trying to set up a part template for sheet-metal usage, that automatically updates a note in the template that is linked to custom properties.
So that when i create DXF/DWG i wont have to add thickness, material,
But cant seem to get Thickness of part to show the estimated value, but it only wants to show Value/Text Expression.
Material shows esitmated value,
weight shows estimated value
but thickness shows Value/Text Expression
Anyone know why material and weight work but thickness wont?
Attached Template and test part.
Got it
Even though "Thickness@Part.SLDPRT" is evaluated in the custom properties window, it indeed doesn't work in for example a sketch. I found an item in the knowledge base regarding this, from 2013. Apparently they changed its behavior then. The new property name is:
"Thickness@Sheet-Metal@Part.SLDPRT"
