Hello Everyone,
I load a part model (3D cube) through macro and then i do some calculation and select one of the faces. I want to now zoom fit my model so that the selected surface is viewed. Is there a way to do it?
Regards,
Prashant Mohan
Hello Everyone,
Regards,
Prashant Mohan
If you made the normal to selection and then the zoom fit command. See example for normal to command.
2015 SOLIDWORKS API Help - Get Normal of Planar Face Example (VBA)
Select the face, run the command normal to and then zoom to fit.
C#: Entity swEntity = swFace as Entity; swEntity.Select(false); swModel.Extension.RunCommand((int)swCommands_e.swCommands_NormalTo, ""); swModel.ViewZoomtofit2();
