I have a nice but complex 2D Sketch. I have no issues extruding this sketch. BUT, I want the resulting solid body to be extruded a little further at one side of the sketch than the other.
To clarify my question assume my 2D sketch (on the left plane) were a simple rectangle and I wanted to extrude this sketch across the top plane where the result on the top plane were a trapezoid (rather than, when using a standard extrude, you'd wind up with the a rectangle (or square)). Of course the simple solution to THIS example is to profile the trapezoid and extrude IT -- BUT since my real problem involves a complex sketch it is not so simple.
The attached model contains the complex profile, extruded. BUT, it is not correct as I want the extrusion to 3/16" wider at the front plane than at the "back" of the model (end opposite what touches the front plane). Both "sides" of the model should be angled outward to create a symmetric solid 6.125" wide at the front plane and 5.973" wide at the "back".
