As a current CAMWorks user, my concern was how nice will SolidWorks CAM play with parts I previously programmed in CAMWorks. Upon opening a 2.5 axis mill part that was previously programmed in CAMWorks 2012 SP1, SolidWorks CAM pops a message that reads: "The SOLIDWORKS CAM data in this model will be converted when saved."
How can there be previous SOLIDWORKS CAM data? It didn't exist previously. Shouldn't this not prompt that CAMWorks Data was present and it will convert it to SOLIDWORK CAM data? Sorry this reads confusing to me, and there are differences between the two versions of which somethings may not convert so I though this should be made intelligent enough to detect CAMWorks vs SOLIDWORKS CAM. Anyone else agree?
Brian,
Thank you for the question. As you may know SOLIDWORKS CAM is powered by CAMWorks. One of our goals was to make sure the SOLIDWORKS CAM and CAMWorks are compatible. This would allow existing users of CAMWorks to communicate with SOLIDWORKS CAM users and vise versa. The message you are seeing is the ability to convert the 2012 data to 2017 in the same fashion that you would with CAMWorks 2017 or a SOLIDWORKS CAD file . We want to make sure that whether you program a part with CAMWorks or SOLIDWORKS CAM, you can share your ideas. This would also allow a user to have some seats of SW CAM and a couple seats of CAMWorks without the need to recreate a program. We are also working on some other scenarios for different use cases that cannot be shared at this time.
Kind Regards,
Mike
