I have a variable where all the data needs to be converted to upper case. There are about 40,000 instances of the variable in the vault. I don't care that the old revisions are updated -- I just want it all in upper case. ...and I don't want to retype everything one file at a time through the PDM Explorer interface.
Please point me in a direction for solving this.
Regards,
Thys
Hi Thys,
This is probably not going to happen without an API add-in. I've run into this before and created an add-in to do this because Dispatch cannot change variables to upper or lower case.
CAUTION: Editing the SQL database directly is NOT recommended and NOT supported. Please do not consider doing this as an option.
We have a paid add-in that does this. If you'd like more information, PM me. We also have lots more add-in products that may help you.
Hope this helps,
Tim CEPA
Believe in The Q!
