Hey all,
I was wondering the best method of going about capturing a feature of a part onto another block. We design Progressive dies and build all our blocks around the strip layout. If the part im designing has for example an emboss feature on it and I want to capture that feature onto top and bottom blocks(one concave the other convex).
both blocks measure 2x4x4. What's some good ways to go about doing this also if I make a change to the emboss on the strip layout will my top and bottom blocks automatically update?
Thanks!
You can either insert part into part and then remove the material using combine or indent tool.
In assembly, you can use cavity option OR offset surface to capture the shape and then cut with surface or similar option.
Again, the method to pick will depend on the feature.
