I need to display file name and file size in drawing notes. I know how to link a note to filename, but I don't see anyway to link to file size. Is there a way to do this?
Also don't forget this little fact. The file size of solidworks files change oddly, for no easy reason to see. Many times I've opened a new part, added a sketch, then saved. And by doing just that the file size became 30% smaller, or 40% larger. Or just re-save it and it gets smaller for no reason I can tell.
Personally, I wait until the end of a project, then just use windows explorer to get the data size then.
I'm curious why you would want that?
In you example the file is an assembly.
Do you just want the size as stored of the assembly file? The drawing file?
Do you want to know the size of each and every part contained within the assembly?
