I have a bracket that is machined, then, at the assembly level, additional holes are drilled in the part and nut plates are installed. Is there a way to do that in Solidworks 15 SP 5.0 and Windows 7 Professional?
Thanks Christian Chu & Fraser Port. I'll try that. I've been away from Solidworks for a year, and I'm getting reacquainted with it. I appreciate the tips!
If you want to go a little more detailed than an extruded hole the hole series feature in assemblies may be worth checking out also.
Todd,
Since this question seems to be answered I would also add that Solidworks lends itself pretty well to post assembly machining. We do a lot of post assembly machining, and the hole wizard, extruded cuts and swept cuts lend themselves to this process pretty well.
I'm a huge fan of the assembly features - I used these a lot at a previous employer, we had a lot of wood parts that were cut on a cnc router, assembled, and then they would be "shaped" as an assembly with a hand router - they are fantastic tools for this!
I rarely use these tools at my current employer, but I saw the post and jumped in to see if there was anything new.
I left that place about 12 years ago, and have only used assembly features a handful of times since then . . .
todd
Yes, at the assembly level, you can add a sketch and extrude cut to whatever part you want to cut
Also you have option if you only want to show it in the assembly or on the part
