Hello Everyone,
We recently ungraded our EPDM system from 2015 to 2017 and I was playing around with the new "Set Revision" Feature. I noticed that if you use Set Revision and try to "Roll Back" the revision change, the local revision is NOT roll back. You have to use the "Set Revision" command to roll it back. This is not a huge problem but I was wondering if this will affect the roll back revision that are done through transitions. This was a big problem in the past where you when you roll back increment revision transition, the local revision was not roll backed. You had to create a new transition that increment the revision in the minus direction (-1 increment in the setting).
Has anyone noticed any roll back problems with transition revisions? Any info would be appreciated. Thank you.
Hello Everyone,
I created some test files and tested this situation. From my test, rolling back the "increment revision" done through a transition will roll back the local revision as well. Thanks for all the input.
