Turn off sheet format with API
Question asked by Damian Gillespie on Apr 19, 2017
Latest reply on Apr 19, 2017 by Damian Gillespie
Hi All,
Not a programmer but trying.
I am trying to turn off the sheet format of a specific sheet named "DXF Sheet". There could be multiple sheets in the drawings but only this sheet is to be turned off. The code below is not really doing what i want. For some reason it is turning the active sheet off from when i start the macro. I need to cycle through all sheets to find the correct sheet then turn off the "DXF Sheet"
Any help would be great
Cheers
Damian
Dim SwDraw As DrawingDoc, SwSheet As Sheet
Dim DXF_Sheet As String
Dim swDrawingDoc As SldWorks.DrawingDoc
  Set SwDraw = Application.SldWorks.ActiveDoc
  Set SwSheet = SwDraw.GetCurrentSheet
  vSheetNames = SwDraw.GetSheetNames
  DXF_Sheet = "DXF Sheet"
For i = 0 To UBound(vSheetNames)
        SheetName = vSheetNames(i)
            'MsgBox SheetName
            If SheetName = DXF_Sheet Then
                SheetName = "DXF Sheet"
                SwDraw.ActivateSheet (SheetName)
                Debug.Print SwSheet.GetName
                SwSheet.SheetFormatVisible = False
Next i
SwDraw.ActivateSheet vSheetNames(0)
