Opening a design table to edit it when Excel is open also, causes Excel to immediately close. I've had this problem for some time now but just decided to ask the question if anyone has the same problem and/or a solution. It's quite aggravating and causes loss of anything in the Excel spreadsheet to be lost if it hadn't been already saved.
We use SW2015 sp4 with EPDM on Win7-64 machines and began when we switched to SW2015. We're no longer on subscription so can't get help from the VAR. Any help would be most appreciated.
Steve
Hi Stephen,
I had this problem in 2015 using SW2014.
How do you open the Design Table, using "Edit Table" or using "Edit Table in New Window"?
When I started to use only the "Edit Table in New Window" this issus just stoped.
Since that I didn't have this issue anymore. Now, even using "Edit Table", the problem doesn't happen again.
