I've never had a problem with the default color scheme used in CAMWorks. Namely the magenta fonts, light teal stock preview, green feature preview/outline, red rapid moves, blue feed moves, etc. The one item I would always do is bump the line weight up to 3 from the default.
All the colors have changed in SOLIDWORKS CAM and I personally don't see any of them being an improvement. The yellow font is nearly unreadable and the default toolpath colors are hard to see and even harder to distinguish rapid moves from feed moves.
Tyler,
The yellow is being changed to a darker color in future versions so it can be easier to see when using non-standard SolidWorks backgrounds. The toolpath colors should be darker and Rapid moves have been changed to green in the simulation vs. red in CAMWorks. Please make sure you reset your default colors if you are using CAMWorks as well. Also please keep in mind that CAMWorks has not been updated yet and you may experience some inconsistencies between the two programs. You are welcome to submit some color changes that you feel make the product better and we will take them into consideration going forward.
Kind Regards,
Michael
