I have a customer who has set up a Convert task to create STEP files.
The driving filename and number at customer for production, is the drawing's, which differs from the part's filename.
Everything else, like PDF's, and DWG's will be created from the drawing, the problem is when creating STEP's because the model file has it's own filename and number.
So typically, what we have is:
Drawing 567.SLDDRW. It has Drawing No 567 and Revision B which can create files like 567_B.PDF, 567_B.DWG, and so on)
The drawing however, is of part 123.SLDPRT. It has Part No 123 and Revision F.
What the customer wants is to make the part inherit, or the convert task use values from drawing when creating the STEP, so the package they send off is:
567_B.PDF
567_B.DWG
567_B.STP
Can the Convert Task be modified to fix this? Macro? has anyone had a similar thought and solution?
The task script could be modified to handle this. You'd need to find the reference from the drawing and then get the variables for the part. It shouldn't be too bad.
