How to fix hole series named wrong in tree?
When I use hole series in assembly sw 2015. it will execute the feature correctly but named as previous feature.
to correct the name the feature, I have to edit one more time to fix the name correctly.
Any idea How to fix it?
If you are talking about the name of the feature itself, there are a couple of ways to do this:
If you select the feature, and then hit "F2", it will prompt for renaming.
Another way, is to turn this option on:
