Hi All,
Just trying to create a new vault and I'm getting this warning message:
Does anyone have any ideas what this means??
Thanks!
Hi All,
Thanks!
Hi Joy,
Thanks for the reply! Gave the suggestion a try and I still cannot create the vault (same message as before), banging my head against a brick wall now.
Regards,
Mark
Hi Joy,
I did attempt to create a PDM standard vault last week, couldn't get that working (had the wrong serial numbers and was using SQL 2014) I removed SQL 2014 and installed SQL 2012 today and went ahead with the correct install of EPDM.
Mark
There is nothing wrong with using SQL Server 2014. So, no vaults? Is there a ConisioMasterDB database? Are you trying to create a Standard or Professional vault?
I have the same issue. I have readed all of the post, and I'm not able to create the vault yet. This is from last year...so, you finally you did create the vault? What was the issue and what you do to solve it?
Thank you so much, best regards.
Jon.
Hi Mark, It might be an orphaned database file. Log into the customer portal at SOLIDWORKS.COM and search the knowledge base for S-019761. There is a PDF that explains how to check and resolve if that is the case. Regards, Joy
