Hi
I have an assembly that sits on the top plane with a hinge that can swing a part below the top plane. When I run a Preview, only the region above the top plane is rendered - the region below the top plane appears to be under the reflective table surface. Does anyone know how to render the region under the top plane as well?
Hi John,
It is probably a results of where the scene floor is currently defined. You would want go to your 'DisplayManager' tab, to 'Lights/Camera/Scene', right click on 'Scene', and use 'Edit Scene' (see below) to see where the floor is defined.
The option for 'Align floor with' is set to "Bottom plane" by default. You may want to change it to "Selected Plane" and select a plane that is entirely beneath your model as it is positioned now.
