I am trying to create a solid from an imported STL file but keep getting a "faces and surfaces cannot be knitted into one surface" and i can't seem to find out why it is not working.
im also have the same problem with other files.
anyone able to help?
Matthew,
Try to knit few individual surface bodies and then do a final knit with these 2 bodies
During the last knit, enable the option to "create solid"
If you window select or select all option fail, if there is any surface bodies in the air (I think this is the cause to fail)
Hope this works
