NGNorbert Gal13/04/2017
I have an application, what traverse through an assembly's all subassemblies and parts, and I'd like to get custom info all of parts and assemblies.
My problem is, I can not get/set custom properties if a component is lightweight.
I've tried that to set lightweit components to resolve before I'd like to handle property, but in case of a huge assembly that takes very long time to finish the whole traverse.
I have a traverse function with a variable what contains a current component:
Comp As SldWorks.Component2
If I'm right, Ican only get/set custom properties in ModelDoc objects, so I get the Modeldoc the way below.
(confStr is a String what is declared previously)
Dim CompModel As SldWorks.ModelDoc2 = Comp.GetModelDoc2
If CompModel IsNot Nothing Then
   Dim PartNo As String = CompModel.GetCustomInfoValue(confStr, "PartNo")
The problem is, if component is lightweight, CompModel will be Nothing.
Is there any other way to get/set component custom propertiesif it is in lightweight?
thank you
